Jupiter 3/30/06, f25
Started by fugardi, 03/30/2006 06:56PM
Posted 03/30/2006 06:56PM Opening Post
After the passing of the high clouds I started "imaging" Jupiter after 1AM, knowing the transit was 2:30AM. Even with my best collimation, I could not focus my webcam on the low hanging planet, not matter what I tried. Finally, by 2AM the detail was starting to improve and Jupiter was finally out of the trees. By 2:15AM I was surprised to see the Great Red Spot appear! With such a small window of time, I decided against trying the no raw mode. The "best" seeing which was really considered "average" peaked 15min before/after the transit time. By 3AM, the image of Jupiter was already too unstable.
This shot was taken right at the transit with normal Toucam factory settings, C11 w/2.5x powermate, Toucam Pro with IR blocking, 135sec, 5fps, 1/25sec, 50% Br, 0% Gam, 100% Sat, 10% Gain, Auto off, best 200 frames stacked with Registax. This shot is my first capture of the Great Red Spot. I would like to try the no raw mode next time, but am afraid to waste my 30min of "reasonable" Jupiter seeing in case it does not work again. At this point, we can only wait for 1 chance at perfect seeing between now and the opposition in April. Good luck getting at least one 5/5er!
Regards,
Steve
fugardi's attachment for post 30660
Posted 03/30/2006 09:18PM #1
Robert, thanks for the advice. Technically, I should be able to go into virtual dub and "hack" off the last 45sec and reprocess. I did try 10fps and thought 5fps was better, unfortunately I determined this by 2AM before the seeing improved. This imaging business is not easy...
Regards,
Steve
Posted 03/30/2006 10:17PM #2
A fine image Steve.
Regards,
Ed Roach
Posted 03/31/2006 06:45PM #3
Thanks for your kind words on my latest Jupiter shot. Normally 90sec is the typical image time for Jupiter, but the excellent images taken by Jim at 180sec seem to contradict that rule. My last time out I "split the difference" and tried 135sec. Keep in mind my Toucam frame rate was too slow at 5fps, and it should have been 10fps, but for this experiment it should not matter.
I took the 135sec avi taken 3/30 right at the 2:30AM Jupiter transit and cut off 45sec from the beginning since the frame quality was worse at the start. Then I processed them in Registax with a 1.5x resample rate. I compared 135sec vs 90sec, and 100, 200, 412 frame stacks. Image processing was the same, except the 100s had to be sharpened a little less to avoid severe distortion. My conclusion is that the 135sec is BETTER than the 90sec, and 100 good frames are better than 412 mediocre ones. In this case, under severe seeing, the final image quality is more of a function of frame quality than the rotational degrade effect of Jupiter itself. So for the northern observers this season, we should be collecting longer than 90sec avis in attempt to capture more high quality frames.
I attached my comparison but the details may not be as clear as they are on my computer screen. Collecting 180sec avis (or longer) can easily be sliced into smaller segments using virtual dub if needed.
Regards,
Steve
fugardi's attachment for post 102314
