M 8
Started by astroguy, 05/07/2004 07:10PM
Posted 05/07/2004 07:10PM Opening Post
Took this image two nights ago after playing with some software, the mount, and then at 1:30am decided to image in Ha.
This is taken with the Modified Aquarium Chiller hooked up, no secondary cooler running. Ambient temp was 61 humidity 89 %
After 50 min settled down to -25 for the images. 90% cooling. Use to be lucky if I got to -10 in this temp last year. Since I would not run it over 90% for fear of a the ambient temp changing briefly going higher and making the image warmer.
This was taken with MaximV4 and dithering used, and seperate guider. Still learning this software as anyone who has it more than likely is too
SBIG 10xe
-25 degrees
7 x 1200 sec Ha 6nm Astroden filter
FSQ 106
astroguy's attachment for post 15695
Posted 05/07/2004 07:57PM #1
Excellent Image Mark!
Beautiful detail, as usual!
Thank you for sharing!
Ivan
smile
