m27 final rendition
Started by Larry Citro, 12/07/2004 07:13PM
Posted 12/07/2004 07:13PM Opening Post
hi,
This is the final processing of my recent image of m27. Taken with a Mewlon250 and ST10XME. LRGB 60:15:15:15 minutes.I had a hard time getting the proper teal color in the middle of the nebula, and it took some processing tricks.
http://starryforge.com/m27/m27LRGBppaFinal.jpg
comments welcomed and appreciated,
Larry Citro
Posted 12/07/2004 10:27PM #1
Larry, having problems seeing your image at the link posted. Either they are down or your link is dead... could you post you pic here?
Ivan
8)
Posted 12/07/2004 10:44PM #2
Posted 12/08/2004 12:08AM | Edited 12/08/2004 12:09AM #3
Larry,
I think you did a great job on the color and the image acquisition. Let me make a suggestion, however. You are clipping the left side of your histogram. You can see this here, where I am looking at the levels in PS for your whole image:
http://www.pbase.com/jhapeman/image/37254118.jpg
Note that the black curve that defines all of your data is bunched up against the left side, and chopped off.
If I select the just the middle of the nebula, it is fine:
http://www.pbase.com/jhapeman/image/37254120.jpg
A clipped histogram means that you are throwing away data; on the left side, it is the faintest data. In your case, with such a long exposure, you probably lost some faint outer halo of M27 that I bet you captured. It also makes the sky unnaturally jet black.
I hope you take this as a helpful comment; you are doing great here, and it is easy to clip the histogram in processing (especially if you mess with the brightness or contrast settings, rather than using levels or curves to adjust the image).
Jeff
Jeff 8O
Posted 12/08/2004 03:05AM #4
Larry,
Very nice shot. I agree with the histiogram comments. Also, if you apply a gentle minimum filter with some feathering you will get less harsh stars. Your star color retention is good though.
Tom Davis
Inkom, ID
Starsearch Observatory
Lat 42N 47' 00" Long 112W 10' 47"
Elev 1752m
www.tvdavisastropics.com
Posted 12/08/2004 12:02PM #5
Finally got to see it today, as it would not work for anything yesterday!
Very nice shot Larry, beautiful color & detail!
Thank you for sharing,
Ivan
8)
