Mars 11.04 @30fps
Started by agonggo, 11/05/2005 06:16AM
Posted 11/05/2005 06:16AM Opening Post
Hello,
While imaging last night with my new cam, I was testing the image quality of different frame rates. The image I posted earlier was done using 15fps. This image was done with the cam runnig at 30fps uncompressed! I was over 1,600+frames/channel for a 1 minute run for each channel!!
Is this better than the 15fps?
Regards,
Chris
agonggo's attachment for post 27909
Posted 11/06/2005 06:28PM #1
Hi Chris -
Congratulations on your new camera - the results look great.
I think with mars at its current brightness 30fps is probably best with your 11". I use both 15 and 30 with my DMK camera, depending on the subject brightness and the seeing conditions and have gotten decent results either way. You need more good frames to stack at 30fps than at 15fps. Saturn will be a more interesting test because it is much dimmer. When your seeing conditions are very stable you might find that 15 fps is the optimum setting.
best,
Alan
Alan Friedman
Posted 11/06/2005 09:01PM #2
Very nice Chris.
Regards,
Ed Roach
