mars image 21st June 2003 - 21:57UT
Started by weileong, 06/23/2003 01:42PM
Posted 06/23/2003 01:42PM Opening Post
Dear friends,
This is an additional mars image from 21st June 2003.
URL to the image at:
http://www.sg-planets.org/mars/mars200306212157ut.jpg
This image is done with the true tech magneta filter and IR blocker. For more information you may refer to this article from the following URL.
http://www.sg-planets.org/toucam_mars.html
The main difference between the UV-IR filtered image and with the UV-IR+magneta filter is the lack of green ghost (surface details) in the B frame as well as no saturation of following limb in the Red frame. The raws are much easier to process. This method with the magneta filter works as expected according to the article.
You may compare this image with the UV-IR filtered one at the following URL.
http://www.sg-planets.org/mars/mars200306212136ut.jpg
weileong's attachment for post 7091
Posted 06/23/2003 02:02PM #1
Tan,
Boy you are producing some great planitary images, thanks for sharing and keep up the great work.
Mark
Posted 06/24/2003 12:39AM #2
Tan you are the master planet imager. I salute you.
