Mars RGB Imaging - DMK 21f04
Started by vandenkj, 09/08/2005 09:33PM
Posted 09/08/2005 09:33PM Opening Post
Hello,
Seeing was terrible, but I did go out last weekend and take a first shot at RGB imaging with the DMK 21F04. I used a Lumicon manual filter selector and a Astronomik LRGB Dichroic Filter Set (Type II with Built-in IR Block). The telescope was a Meade 12 SCT with a Televue 3x barlow.
I am anxious to try it again on a night with better seeing, as I am encouraged by the results. I did have to probably over use wavelets and unsharp mask to get this final image as the seeing yielded very poor frames in the AVIs.
Kirk
vandenkj's attachment for post 26681
Posted 09/09/2005 02:40PM #1
Hi Kirk,
That's a fine image for such conditions. You processed it very nicely.
Regards,
Ed Roach
Posted 09/09/2005 05:55PM #2
Hi Kirk,
Very good results from your first RGB image, that camera and scope combination are going to be great when you get better seeing.
How many frames for each color and capture length ?, if I remember correctly you are imaging in Alt/Az (so am I), is it hard to get in enough frames for each color before field rotation or Mars planet rotation sets in.
Wes Higgins
