james carter
North American Nebula NGC7000
Question about Registax 3 and field rotation...
Started by IGastaldo, 01/03/2005 09:52PM
Posted 01/03/2005 09:52PM Opening Post
One quick question, as I'm having a lil' issue with Registax 3 compared with Registax 2...
As I've stacked a series of images in both (same images for both), I can see field rotation in the final result in R3, but in R2 everything is fine...
Any ideas what could be causing this?
Thank you for your attention,
Ivan
8)
Posted 01/04/2005 01:08AM #1
Hi Ivan,
This is a item Cor build in the new version, maybe you accidently hit the buttom "Rotate" at left in the first screen, otherwise I can't explain
best wishes Jan
