Saturn 1/20 AM
Started by GregDamiani, 01/20/2007 07:19PM
Posted 01/20/2007 07:19PM Opening Post
Hi All!
Seeing was very good last night here in So. Fl. 8-9/10.
I did a few imaging runs after observing last night. I didn't intend to do any imaging, but the seeing was real good! grin Unfortunately, I don't think I did a very good job focusing. >sad
Here it is.
SM 14.5 w/ goto and track
TV3x barlow
Toucam 840 w/ infrared block filter
Registax 4
370 of 440 frames
First time trying Registax v.4. Opinions on multiple vs. single point alignment for Saturn? If multi, how many, and what points do you pick?
Thanks.
Gregg
GregDamiani's attachment for post 35427
Posted 01/20/2007 09:31PM | Edited 01/20/2007 09:35PM #1
Hi Greg -
Nice image.
[First time trying Registax v.4. Opinions on multiple vs. single point alignment for Saturn? If multi, how many, and what points do you pick?
Sharpness variations across the field from turbulence give an advantage to performing alignment on multiple regions. The improvement gained by multiple alignments increases with the size of your chip (or in this case, the amount of the chip used in your image, hence, the focal length used). The improvement becomes less significant as the quality of the seeing improves. At this image scale and in 8-9/10 seeing I would say it is not going to give much, if any improvement. At f40 in 5-6/10 air you will see an increase in sharpness of the cassini division if you align the image on each ansae. This is typical for my set-up and location - I often perform 4 alignments - right and left and south and north.
hope that helps -
Alan
Alan Friedman
Posted 01/20/2007 10:02PM | Edited 01/20/2007 10:02PM #2
I've not gotten much improvement the few times I've tried
multi on Saturn. I think the best case for multi is
lunar where you've got high-contrast alignment points all
across the CCD.
Posted 01/21/2007 01:50PM #3
Gregg, gorgeous Saturn! Congradulations just to be out there observing in near perfect conditions. Thanks for posting
Regards,
Steve
