Hi All,
Having recently made a move to an SBIG STL11000M CCD, one of the challenges was an
exposure minimum of 0.01 seconds... too long given the high sensitivity of the camera. Matt L,
(SBIG engineering/software) came to the rescue with a driver patch which allows the
exposures to be reduced to 0.001 seconds, and I'm pleased to report that it works like a charm!
There's enough headroom to reduce the image intensity even below the threshold produced via
my brightest (2X Powermate) solar H-a sessions, without additonal filtering!
Briefly:
With a 2X Powermate and 1x1 binning, optimal dynamic range for the solar disk comes in at around
0.004 seconds (0.005 causing the white level to just bump into saturation, 0.004 putting things
around 64K, and 0.003 a tad below 60K, on a range of 0 to 65,535.)
The 4X Powermate and stacked 4X/2X Powermates even allow 2x2 binning now.
The image below is a quickie from one of the 2X Powermate shots @0.004seconds (AP
Traveler/Solarmax 90/single image taken 29-Apr-04)... no additional polarizing pair or
knock-down filters used!
Gotta' hit the road now... early day today (yawwwwn!)
Paul
--- http://www.astro-nut.com ---
Briefly:
Paul
