Ghost of Cassiopeia
Titan f25 RGB 3X, reprocessed from 2/24/08
Started by fugardi, 03/13/2008 09:32PM
Posted 03/13/2008 09:32PM | Edited 03/14/2008 01:04AM Opening Post
While waiting better seeing conditions, I went back and reprocessed my C11 DMK21 Titan RGB avis from the opposition, trying to hand pick the best ones from each channel. The result is a less blurry image but still no surface details. For Titan, the G channel proved to be the strongest. With clouds moving in, I was only able to take 4min of each channel. I would guess that under perfect conditions, some surface details could be captured.
Regards,
Steve
fugardi's attachment for post 41249
Posted 03/14/2008 01:19AM #1
Usually I bite my tongue and hold back but exactly WHAT do you expect to see in the way of details on Titan?
Posted 03/14/2008 02:56AM | Edited 03/14/2008 02:57AM #2
Hi Steve, that's a tough nut to crack alright, but I have viewed sharp amateur photos of Titan, everything has to be just right to pull it off. Right now Titan is at its maximum western elongation, but in four days it will be very close to Saturn, providing a good photo opp. Here is a NASA site that proves there are surface markings, I found the page to be very interesting. http://solarsystem.nasa.gov/planets/profile.cfm?Object=Titan Cheers, Dan grin
Posted 03/14/2008 03:34AM #3
Hi Steve,
Great job resolving the disk of Titan!
You had mentioned that "I would guess that under perfect conditions, some surface details could be captured."
I don't believe that you will be able to capture surface details of Saturn's moon Titan in the visible spectrum. The Voyager spacecraft couldn't and it passed very close to Titan with cameras. The only reason that the Cassini Spacecraft can see anything is because after Voyager's failure, they figured out that they needed to use a near infra-red camera at 2 distinct frequencies (is it 0.94 microns and 1.08 microns?) to pierce the veil of Titan (and they use an active-radar too because even the IR camera is limited.) The near-infrared colors are 3 times redder than what the human eye can see. I believe the instrument they use for that is the Visual and Infrared Mapping Spectrometer [VIMS-IR] which operates in the spectral range of 0.85 to 5.1 µm. VIMS takes shots in wavelengths between 300 nm and 5100 nm, but the visible spectrum that you are shooting within probably is closer to between 400 nm and 700 nm? So bottom-lining it, the wavelengths used to see Titan's surface are longer. Perhaps there are cameras used by amateurs that are IR sensitive enough in the the near-IR frequency domain that they might capture something with filters? But I sort of recall that the window is very limited to 2 IR frequencies, and I imagine that the Earth's atmosphere could be another impediment to using that effectively.
Regards and nice Titan disk! Jason Higley
Regards,
Steve
Posted 03/14/2008 07:28PM #4
This picture was taken by Daniele Gasaparri.
Check it out.
alvarogaray's attachment for post 121020
Posted 03/15/2008 07:25AM #5
Hello:
Not to rain on your parade, but you're not going to see surface details on Titan. Surface details on Titan are very hard to see even with adaptive optics on the largest telescopes in the world (having done it myself), and by observing in the infrared at specific wavelengths where TItan's atmosphere isn't completely opaque. Cassini has clearly resolved surface details by observing at the apropriate wavelengths and by being very close. Surface details on the Galilean satellites is possible to resolve, however. Those are probably the only satellites where amateurs have a shot at resolving surface features.
Cheers
Mike Connelley
