Iris Nebula
Types of barlows to use for imaging?
Started by Mike Wirths, 08/09/2005 06:37PM
Posted 08/09/2005 06:37PM Opening Post
Hi all,
I got to wondering today about optical quality and design of barlows. We can spend buckets of money on good scopes and cutting edge cameras like the lumenera, but if we use a cheapie barlow we can lose quality! I myself have a regular 1 1/4" 3X's Televue and a 5X's Televue Powermate.
According to the Televue site the Powermates are supposedly better than the purely visual regular barlows for imaging because of a better spot size with less edge distortion. I'm thinking of selling my regular 3X's and getting a 2.5 Powermate and maybe a 4X's powermate (very $$$). This would give me lots of flexibility of image scale and would be able to respond to variable seeing better.
However there are other companies out there that make premium barlows like Takahashi, Astro Physics, Baader etc, has anyone had any experience with them? On a local Toronto vendor I saw these for sale by Baader, they are specialized for solar work perhaps they would also work for our purpoes?
http://www.kendrickastro.com/astro/ep_baader.html
I ordered one of the new Lumenera infinity 2.2's yesterday, I can hardly wait to try it!! The filesizes for that camera will be huuggee!
cheers
Mike W
Posted 08/09/2005 08:09PM #1
Mike -
I've used several of the powermates, the A/P 2X barlow (pre-barcon) and the Baader FFC that is sold through Astro-Physics in the US. They all work beautifully - it comes down to which are the best fit for the focal length of your scope. The FFC can be used from about 3X to 8X with the addition of extensions. The powermates do not change the position of focus much when inserted into the optical path which can be a small convenience. The 2" barrel powermates are quite heavy.
Alan
Alan Friedman
Posted 08/09/2005 10:19PM #2
Hello Mike,
Which vendor did you order the Lumenera from, or did you order it directly from Lumenera?
Kirk
Posted 08/14/2005 05:55PM #3
Hi Mike,
I have recently begun investigating the answer to this question myself. For one thing, I find that the standard 1.25" Televue 3x barlow shows vignetting even when used at its design length. Normally, the vignetting is not too prohibitive unless extending to 4x for Lumenera or other use and then the vignetting becomes severe. I am currently investigating other options and I suspect better performance from the 2" sizes since the light cone should be larger. The key with the barlows seems to be using them only at their designed length. Any deviation appears to cause problems. Good luck.
Eric
