When BIG is just TOO BIG... (long)
Started by IGastaldo, 03/26/2004 07:39PM
Posted 03/26/2004 07:39PM Opening Post
Please don't get me wrong... this is just meant to be a constructive thought...
Well, I've been thinking about this one for a while, and decided to drop a line (well, several actually...), specially for the ones that are just getting into Astrophotography and/or Webcam Imaging...
I'm no expert at all, I started not too long ago, and I've learned much in this little time..., specially after watching/talking/editing/taking shots along with imaging experts here...
As with visual observing, we must understand that scopes and "seeing" work together, and we must know the limitations, not only of our equipment, but also the ones that atmospheric conditions drop on us.
It is surely awesome to see very large scale pictures, when the equipment/seeing allow for such, the images present detail that it is simply amazing... and it is GREATLY APPRECIATED...
But, there are times in which those images are just WAY TOO LARGE, and the detail gets lost in the process, most likely because the seeing conditions or the equipment simply could not handle the magnification requested... or the person just did not know how to process the final image accordingly and blew it out of proportion...
BIGGER is not necessarily BETTER, we must learn to BALANCE the different aspects of Astrophotography in order to get a fine & well resolved image at the end...
Like when you visually view a planet, you start with lower mag and push to higher mags until you start seeing breakdown, then you step back to the one that gives you the best image for the seeing conditions. The same is for imaging, you go f/10, f/15, f/20, f/25, f/30.... too much? then step back to the best possible combination... 1024x768, 800x600, 640x480, 352x288... same, drop size if too much...
Any thoughts?
Clear skies!
Ivan
smile
P.S.
Again, please don't get me wrong, this is just meant to be a constructive criticism... specially for the New Imagers, but not geared to anybody in particular...
This is just based on personal experience, and I'm trying to pass it along to all the ones that could use it...
Posted 03/26/2004 08:16PM #1
hi,
i present the images at 765 x 530 or 1024 x 768 but never larger than that. If I want to show some detail assuming its there, I'll crop the image to the area of interest.
Basically, I agree with you.
clear skies,
Larry Citro
Posted 03/26/2004 11:26PM #2
Hi Ivan -
If I understand your point correctly it is about the presentation of the image more than the image scale captured on the chip?
I often res up an image (increase the pixel size) during processing and then size the image smaller for display. This was an image captured in poor seeing that I posted a while back - way to big, I thought after seeing it on the forum. It is more pleasing in the smaller inset, and there is really no compromise on the detail.
best,
Alan
Alan Friedman's attachment for post 77923
Alan Friedman
