The dark side of imaging force clouds everything ... ;-). Being a pure visual observer, I've been toying with idea of experiencing the power of imaging recently.
Still knowning next to nothing about webcam but I've been learning ;-), I'd like to get my "focusers" wet soon. I've been reading up on the how-to's and the reviews and have some idea about some cameras. I'm mainly interested in planetary and lunar imaging and may dabble in DSOs some day. No black/white camera - I want color (I don't mine if I have to get a different camera for DSOs later but I rather the first camera does particularly well on the planets and the Moon).
Firstly, my environment is with APO refractors: 4" f/8.6 (FL 880mm) or 5" f/6 (FL 780mm) an Vixen SP mount with RA clock drive, being a 4-inch/5-inch Tall Evangelist you know. I also plan to get a 5X Powermate (or would my 2X Ultima or 1.8X TMB barlow that I have be sufficient to start with)? Now I understand the image scale won't be anywhere as big as 'em pictures from the mighty SCT/MCT . I have a 300 Mhz P-II laptop with 256MB running Windows 2000 with plenty of disk space (should this be sufficient to do the capture? - I can process the images later on my 2.4 GHz P4 desktop with 512MB memory).
So it appears that the Toucam Pro II which already comes with a 1.25" adapter, seems to be very popular for planetary/lunar imaging. I realize I'll need an IR filter (perhaps a Baader one).
http://www.optcorp.com/product.aspx?pid=4086&kw=Toucam&st=2
While researching, I ran across the SAC.
http://www.sac-imaging.com/main.html
SAC 10 looks intriguing but much more expensive. However, I don't see much of planetary pictures taken through the SAC and those I've seen so far don't look as good as through the Toucam.
So the question is: what should I pick? Are there any other color webcam that is "better" than the Toucam (but not too expensive)? I'm not a handyman and actually get turned off if I have to make accessories myself or have to adapter the camera a lot (don't mind learning the software however). I don't mind paying a little more if it can yield better and more painless results ;-). What about cooling? Do I really need it for planetary pictures?
Finally, I'll start out with the Moon first, try my hands at Jupiter and hopefully get enough experience by the time Mars swell hugely later this year ;-).
Ron B[ee]
Ron B[ee]
