Max Resolution test
Started by RolandC, 09/21/2009 03:05PM
Posted 09/21/2009 03:05PM | Edited 09/21/2009 04:03PM Opening Post
Hi All,
Testing resolution limits at my site last week, I did some experiments to see how pixel scale affects max resolution. I had seen improvements in the past on small faint objects like the Einstein Cross when I increased my pixel scale.
Amateurs usually opt for faster focal ratios in the belief that it will increase their signal/noise ratio. They also sometimes bin their color data, i.e. shoot the luminance at 1x1 and the color at 2x2, thinking that the luminance will compensate for the lower resolution color data. Sometimes that works when the seeing is not very good, but even under not so great seeing, shooting at 2x2 does degrade the results.
Attached are 3 shots of the core of M13 compared side by side. All shots were taken with my 12" Mak-Cass and ST10XE camera. I stacked an number of short 10 second unguided exposures.
#1 shows pure RGB taken at 1x1 binning. #2 shows 2x2 binning, twice as many exposures in an effort to get better signal/noise. #3 shows the original 1x1 RGB with 20 seconds of luminance added.
Result as you can see, the pure RGB has the highest resolution. You can see many faint stars that are washed out in the 2x2 RGB. Even though the 2x2 binned image has less background noise, and it is twice the length exposure (giving theoretically 4x better signal/noise) it does not have better signal. There are fainter stars in the 1x1 image. The third image shows how adding just a short luminance set (two 10 sec L exposures) improves the background noise dramatically and preserves the resolution.
I like to use the four stars in the short arc on the right side of the core as a guide to the resolution of the core. These images have not been sharpened or processed except for stacking.
Rolando
RolandC's attachment for post 48361
Posted 09/21/2009 03:24PM | Edited 09/21/2009 03:25PM #1
A quite dramatic and convincing demonstration. The labeling on the middle photo is incorrect though in that it says 1x1 binning on the photo and you say in the text that it is the 2x2 binning example and it certainly appears to be the worst resolution of the three.
Posted 09/21/2009 03:36PM #2
Rolando,
Thanks for confirming my suspicion that 1x1 is the way to go when doing LRGB imaging and this is something which I have NEVER deviated from.
Now, I hate digressing BUT what impresses me most about this little result is the fact you have colour all over the cluster and this is something quite difficult to get when imaging globulars. Good stuff!
Anthony.
Posted 10/07/2009 08:01PM #3
Roland,
would you say your conclusions are also valid when shooting at lower resolution - for example, with AP160 and STL11K @ 1.46"/pixel?
I have been using unbinned "Luminance" and "RGBs" for all my recent images... mainly because, being lazy, I can get away with less Darks and Bias frames.
Maybe I am doing the right thing, but for the wrong reasons? :-)
Regards,
António Rosalino
PORTUGAL
