Re: replacement diagonals for LX90
Started by IGastaldo, 03/10/2006 02:18PM
Posted 03/10/2006 02:18PM | Edited 03/10/2006 02:18PM Opening Post
All SCTs come from factory with SCT diagonals, which screw into the visual backs...
If you want to use refractor style diagonals, you would either have to change the visual back to a compression ring style, or use an SCT adapter, which screws into the visual back, and then you insert the diagonal into it...
I particularly use a 2" AP visual back with compression ring, and then I insert my 2" TV diagonal into it... 8)
Posted 03/13/2006 11:42PM #1
With all due respect all SCTs I know of do not come with SCT diagonals. They come with a SCT visual back that converts the 2" SCT threads to 1 1/4" threads but also have a set screw to accomodate standard diagonals. The included diagonal is generally a standard 1 1/4" diagonal.
David
