FC100 (help)
Started by SmokeDaddy, 04/25/2007 04:43AM
Posted 04/25/2007 04:43AM Opening Post
Hello,
I'm looking for some specific (note the specific) help. I would like to attach my Hutch Rebel to a FC100 for imaging purposes. Can someone give me the exact components I would need to accomplish this task? An individual that is currently working with this setup sent me the picture below, but I haven't a clue HOW to identify the necessary components IN THE PICTURE. Any help with actual parts numbers would be appreciated.
Here's what he said:
I use the DIY rotator + Tak F5.9 reducer + DIY CA-35 + Canon T-ring.
SmokeDaddy's attachment for post 36838
Posted 04/25/2007 07:11PM #1
James --
"DIY" usually stands for do-it-yourself, so I expect those two components were home-built by the poster.
The "DIY rotator" looks to be about the same size as Tak's rotator (otherwise known as a camera angle adjuster or CAA). There are several different CAAs to suit different size focusers -- you'd want TFP1100.
Similarly, the CA-35 is probably the poster's home-made equivalent to Takahashi's CA35 (camera adapter -- TCA1030). I expect you can also get the Canon T-ring from Takahashi (perhaps TWM0004 -- is the Rebel the same as the EOS?).
But the easiest way might be to email/call Art at TNR. I'm sure he'd be able to tell you exactly what you need.
-- Jeff.
Posted 05/25/2007 01:30AM #2
Here's my solution. Home depot plumbing department PVC fittings and a little brain power.
streets's attachment for post 114265
