I just finished the DSC podium for the new Go-To system. It will hold the wiring and the Argo Navis controller.
The bracket is made from Red Oak and is finish just like the Oak on the Starmaster. I used Oak Flooring (simulated) for the pad and put an Aluminum angle piece on for a lip to hold things on the pad. The wiring will go through the tubing and out the bottom of the bracket. There is a 3/4" hole though the bottom bracket to allow the wiring to pass through, then there is a hole in the side of the rocker box near the bracket for them to go inside to the ServoCat. I used 1" aluminum tubing for the stalk. It mounts using one of the wheel barrow handle mounting holes so I did not make any new holes.
What do you think?
What do you think?
