james carter
North American Nebula NGC7000
Orion Atlas mount
Started by vbert, 11/18/2003 01:29AM
Posted 11/18/2003 01:29AM Opening Post
Has anyone out there used the Orion Atlas mount? The solid appearance and price has me intrigued. I would mount an FS 102 on it for visual use and webcam imaging. I have the LXD 55 now and I am very dissatisfied with the stability, not to mention the goto, but I dont really need or want goto for my purposes. When I touch the focus knobs at high mag (200X) it takes about six seconds for the image to settle down.......not very good for visual or webcam planetary focusing. I am looking for a ROCK SOLID tracking mount at a decent price, thanks, Vince
Posted 11/18/2003 03:21AM #1
Hey Vince, Nick is using this mount with his Tak FS 128 and he is very happy with it. Jose also has one of these mounts and he likes it a lot.
Posted 11/18/2003 09:46AM #2
Hi Vince, I took a close look at the mount a few times in a local store and I'm thinking of buying one too. There are lots of options available for the mount to improve the tracking; other motors, pec, different hand-controls,...you can upgrade the mount one step at a time. I was thinking of using it for my 8" and eventually a 14" newtonian, though that might be too much for the mount. I do know of someone who has mounted a 12" f5 on it and it's still stable.
The one I would buy is the Skywatcher Synta model, just the same as the Orion I guess..
APM telescopes in Germany offers several upgrades..
Nico
Posted 11/18/2003 03:03PM #3
Hi Vincent, I too had trouble with the stability of my LXD55 when a AR6 was mounted on it. After a bit of usage I sold the ar6 because the scope was just too much for the mount to handle. I then bought a TV NP101 thinking that the mount would support the 4” APO with rock solid stability. Nope I was dead wrong. Dampening times where still around 3-4 seconds witch was better then the AR6’s 5-6 second dampening time but still not acceptable to me. As it turned out the cause of the vibration is not the mount itself but the flimsy aluminum legs. I have since bought very good legs from KB systems(who make legs for TV) that are made of Purpleheart wood. With these new legs and Celestron vibration suspension pads I have sub second dampening time using 220x. I was shocked at how much of a difference the legs made. As far as the goto goes, I get accuracy that is totally acceptable to me. Keep in mind that with my 31mm Nag I get a 4.6* FOV out of my NP101 so the accuracy does not even need to be that good. It is defiantly worst then my 12” LX-200 but as stated with such a wide FOV it does not need to be dead on. If you are getting horrible goto accuracy I will be willing to bet that a day of twicking the mount and you would be satisfied with it. The first thing to check is if the gear retaining screws are tight. That is the cause of bad LXD55 performance 90% of the time and the rest is ether user error or encoder problems. I have even begun to get into astrophotography with the NP101 and LXD55 combo. It is actually acceptable even for that purpose(see pictures below). Anyway good luck with whatever you decide on. Vlad.
power_overwhelming's attachment for post 73283
