About contrast
Started by fblue, 05/20/2007 04:31PM
Posted 05/20/2007 04:31PM Opening Post
Hi all! I had a nice night Friday at a local site. The seeing was quite steady and transparency was good with temperatures in the 65-75° all evening. Really comfortable and made for easy observing.
I got my first real good look of Jupiter for the year! Every time I looked before the details were just not there.
We tried some filters to see if we could improve the details, colors first, with some improvement with Blue.
Then I remembered that I had bought a Baadar Contrast Filter last year along with a TV Mars filter. So I tried the Baadar and WOW, it really worked! There was a little lateral color induced at the limb, but the details on the planet were much improved with a pleasing color that was close to natural. It took away a little of the glare in the brightness as well as increased the level of contrast on the bands. The difference with and without the filter were very pronounced and I could see much more clearly the details that were there.
The view could have been better if it had been higher in the sky, but the effect was still very good. I was surprised that it worked as well as it did and I will give it more time later in the year as Jupiter moves higher.
Just thought I would post my thoughts on this. smile
Posted 05/20/2007 05:51PM | Edited 05/21/2007 11:59AM #1
You've almost convinced me to add to my filter collection. Did you get a chance to try it on Saturn also?
I got a look at Jupiter last night for the first time this year also but as you said the planet was low in the sky and the temperatures have temporarily dropped here in Raleigh, NC providing a lot of radiant cooling in the atmosphere. In fact after viewing the conjunction of the moon and Venus I turned up the magnification on the moon and the atmosphere looked similar to the air above hot pavement in the summer. Still some nice viewing though.
Posted 05/21/2007 01:44PM #2
Hi Floyd,
You mentioned using a contrast filter on Jupiter. Baader lists two filters: contrast and sky/moonglow, with most of the planetary press going to the sky/moonglow. Which one were you using?
Larry
Posted 06/18/2007 03:25AM #3
I finally got a chance to try the Baader Contrast Filter on Jupiter tonight and it worked very well with a variety of eyepieces, allowing me not only to see bands but detail within them. I should add that I used this filter with a William Optics Minus Violet Filter in the mix, but it still worked fine for me.
Posted 06/21/2007 07:31PM #4
Has anyone tried the 499 FL-D by B+W ?
I used one on Mars and found it to provide greater contrast than any other filter and added very little
obtrusive hue. (It is a pale magenta color).
These filters are used in photography to correct florescent lighting.
It brings out red and blue features, while blocking some green.
I've heard of people combining it with the Baader Neodymium for use on Mars.
I have yet to give it a try on Jupiter and have heard no reports of it.
Posted 06/21/2007 09:42PM #5
Dang it Floyd, now I had to go and order one.
Paul
