I started with I believe a 600 refractor back in 1965. Couldn't "find" a thing with it so used mostly for terrestrial. Then moved up to a 4.5" Reflector which was wonderful. Again, not sure who's brand. After that got some astro fever and ground my own mirror to make a scope plus got an 8" mirror from someplace and me and my dad build a Newtonian around that and used an Edmunds equatorial to hold it. We built the tube out of stainless steel! I recall all the drill bits we went thru poking the various holes in that tough metal. It was a tank for sure, but it sure performed and I'd routinely go 100x per inch with that thing on the Moon. Was out looking at the Apollo landing sites each time they landed or took off from those adventures. Up to this time I had the typical 1.25" eyepieces from Edmunds or Celestron. Then this new thing came out on the market called a Nagler or something so I ventured into my 1st premium EP and spent all my money on 2 eyepieces, a 4.8mm Nagler and a 24mm Wide Field. These things were like a quantum leap over everything else (and I still have them).
After the 8" home made Newt, I downsized back to my 4.25" Newt and that served me forever. Then I went to college and dropped the hobby. Finally, when I graduated and began to earn some money I got back into it and got myself a present of a C-8 Delux. That was one great scope and I used my 2 premium EPs in it, but also had the Celestron Orthos and Erfles which also worked quite well. In transit as I moved from the East coast to Chicago, the C-8 was stolen by the moving company and in the light polluted Chicagoland area I just picked up a Meade 2045 102mm SCT to hold me over. I kept and used that for 10 years before I finally (now back on the East coast) picked up my Orion XT10i and it has been the greatest thing since apple pie. I think a 10" is a great compromise between size and performance. It's "big" but still a very "personal" instrument. With the 10" and it's great performance I have gone EP crazy and have run thru just about everything short of Zeiss Orthos and Meades. So aside from those just about everything else has been in my stall that was worth being in there.
So after all this time, where has the EP journey taken me? To a very mixed spot, not of the one line or perfect EP that everyone is searching for, mut of overlapping EPs since no one EP is strong in everything that I may end up needing while observing. So on the high power end I at times need wide fields so I can get more context. For this, the T6s are used and their primary usage is for Lunar and Globs since they excel there (note the Hyperions or XWs would have done as well or even better in the case of the XWs, but a personal preference of mine is for high power EPs to be a smallish form factor, so this gave the T6s the edge as wide-fields). For sharpest on-axis work for planets and doubles and DSO, I've settled on Tak LEs as being the best in my tests for these objects. Sure the SMC Orthos are a tad better, but the Taks do almost as good plus have the larger afov and the nice 10mm eye relief so better than typical orthos or plossls. But so far, except for the SMC Orthos, nothing (yes nothing!) has been sharper on-axis, nor as contrasty.
On the low power end the search for something I really like in a fast Dob, with it's fast optics issues off-axis, has been really hard - especially since I do not like adding a Parracor into the mix since I have tried it and I don't like the extra magnification and I can detect the light loss from the extra glass quite easily. Add to my problem that I really don't enjoy 2" EPs all too much because I don't like fussing with switching between 1.25" format and 2" and the search is even more difficult. So again, I've had a host of Plossls and Erfles in the longer focal lengths and nothing really stellar IMO. The best view to date has been thru the Panoptics and older TV Wide Fields when I get longer than 15mm. But another personal preference for me has been the discovery that I don't like rectilinear distortion in my low power EPs since I have gotten used to things being orthogonally correct with the Erfles and Plossls I have been using over the years. So when I pop my TV Wide Field for instance in the focuser and look at a familiar subject, the star positions being somewhat off from true just looks "wrong" to me. Same with Panoptics and Naglers in the longer FLs. So my search has not yielded much luck until the 40mm Paragon came along. Now that is nice - every star in the place it should be across the field. But what to do about the 15-25mm range since no Paragon's yet? Well, since I can't wait, I went for the 14mm and 21mm Denks. Beautiful looking, small form factor, big eye lens, good edge correction in the fast dob, and almost zero rectilinear issues! Finally I'm happy
So there you have it, after Celstron Orthos-Erfles and Meade Plossls-MAs and RKEs, and UO Erfles-Orthos-Konigs and Sieberts Ultras-StarSplitters-Observatories and TeleVue Plossls-Panoptics-Naglers-Radians and Pentax XW-SMC Orthos-XFs and BO/TMB Planteries-WAs-Monocentrics and Orion/Baader Stratus-Hyperions and Takahashi Les what I have ended up with are:
**Hi Power Resolution - Tak LEs
**Hi Power Context - Nagler T6
**Mid Power - Pentax XF
**Lo Power - Denks and Paragon
So now that I've found my stall am I finished? Nope
Because I've discovered that if I can get my scopes focal ratio at f/15 or above, then the Pentax XFs and Denks smoke all the high power EPs when the hi power EPs are in the scope at f/5!! I mean smoke them! So if I throw a good 3x Barlow under the XFs or Denks, then the T6s, LEs, and even the SMC Orthos aren't as sharp. So I guess that brings us back to the olden days of scopes for us high power junkies - focal ratio RULES!
It's just never ending - guess that's why it's so much fun
