Grenville base Observatory
Started by bschnitzer, 03/31/2004 02:10AM
Posted 03/31/2004 02:10AM Opening Post
Greetings from Virginia,
GBO is under construction. The exterior is complete, but the interior still has a ways to go. I'm very pleased with the HD-10 from Technical Innovations. I'll gladly share my experiences and insight gained on this project with anyone contemplating a similar observatory.
bschnitzer's attachment for post 14587
Bob Schnitzer
Grenville Base Observatory - Haymarket, VA
http://www.grenville-observatory.com
16" f18 Royce Conical Dall-Kirkham
10" f16 Parks/Coulter/Novak/Cave Classical Cassegrain
127mm Orion Starmax Mak-Cas
80mm f15 Meade refractor
40mm Tasco variable power tabletop refractor
DMK 31AF03.AS
DBK 21AF04.AS
Posted 03/31/2004 03:04AM #1
Bob,
Wonderfull design! Appears that you enjoy great views ALL hours of the day. Show us more!!
Best regards,
Tom Tolla
Tom T.
Guilford, CT smile
Posted 03/31/2004 04:22AM #2
Very nice! What size telescope are you planning for your observatory?
Posted 03/31/2004 07:09AM #3
Very nice indeed.
Floyd
Posted 03/31/2004 10:09AM #4
Congrats Bob! That's a very unique design for an observatory.
Exactly where are you located?
I finally gave in and orderd an HD-10 as well. I should take delivery on 23 April. I am going to be placing mine on short 4' octagonal walls. Any suggestions? Did you use flashing material?
Your view is very nice but I'd cut the trees down
Mike Fleenor
Knoxville, TN
Posted 03/31/2004 06:27PM #5
BEAUTIFUL!
Ivan
smile
Posted 04/03/2004 02:48AM #6
Beautiful! I'm considering a somewhat similar set-up built into the roof of an aircraft hangar. This requires an even taller pier than yours, about 20 ft tall. How did you spec your pier? What kind of foundation? Are you worried it might start to lean? How did you attach your mount to the pier?
Regards
Roald Lutz
Posted 04/03/2004 10:25PM #7
Bob,
Thanks for the info. Did you ever consider an all-steel pipe pier? What made you go for a concrete pier? What did that pier with the engineering and all, roughly cost? Are there any good books on tall piers? So many questions, so little time!
Regards
Roald Lutz
Posted 04/17/2004 06:40PM #8
Bob,
I would just like to say that your Observatory and site location is just absolutely beautiful. I noticed the pillar from ground level all the way up to our mount! I wish that I had your Observatory and that you had one better although I just cannot see how that could be possible.
Congratulations!!!
Respectfully,
Danny Halstead
"Experience is a wonderful thing. It enables you to recognize a mistake when you make it again."
Danny Halstead
Moderator APM Forum
Posted 06/23/2004 05:22PM #9
It's incredible!! Very nice!!
Andy
