Telrad Base Removal
Started by ps, 03/16/2007 06:42PM
Posted 03/16/2007 06:42PM Opening Post
Seeking advise on how to remove a telrad base for a 10” dob that is attached with sticky tape. Any comments and / or suggestions will be greatly appreciated. Thanks in advance, Paul smile
Meade 10" LX200
C9.25 ASGT
Orion 10" XTi
Orion 80mm ST
Posted 03/16/2007 07:08PM #1
What kind of tube does it have? If metal, you should be able to just pull it off with some effort. Warming it in the sun or with a lamp (don't melt it) will help. Rock it at first to loosen the tape. The residue can be pulled away, rubbed of, or removed with GooGone (or so I hear).
If it's a cardboard tube...better ask someone else.
Joe Bergeron
Moderator, Astro-Physics Forum
Posted 03/16/2007 07:58PM #2
Thanks for all the great suggestions smile I have a metal tube and will try the dental floss method. Thanks again, Paul smile
Meade 10" LX200
C9.25 ASGT
Orion 10" XTi
Orion 80mm ST
Posted 03/17/2007 02:36AM #3
Just one more suggestion, charcoal lighter fluid is great for removing adhesive and it does nothing to the finish on the item you are removing the adhesive from.
Real men play Golf
