IC 1396 and vdB 142
Started by jthommes, 10/03/2010 06:32PM
Posted 10/03/2010 06:32PM Opening Post
All,
Here is my shot of IC 1396 this season. It is an HaRGB image. I think this object does OK with this data set. Image is here:
http://www.jthommes.com/Astro/IC1396_Elephant.htm
(click on the image for full resolution version)
Scope - Zenithstar 66 mm APO at f/4.5
Camera - ST8300M, Astronomik 1.25 HaRGB filters
Mount - G11/Gemini
Guiding - C8 at 1350 mm FL, DSI Pro, PhD Guiding
Jim Thommes
Mak-Newt 152 mm
C8
Megrez II APO
G11/Gemini
ST8300M
Artemis285 Camera
Canon 350D DSLR
http://jthommes.com/Astro/
Posted 10/03/2010 06:41PM #1
Great shot Jim! ...Think about an H-Alpha only version. While on the subject, why did you choose 9 minute subs for the H-Alpha?
Brian
Posted 10/03/2010 11:33PM #2
Nice image, Jim!
BTW, your info says that the Elephant Trunk is also called vdB 142. vdB142 is a small reflection nebula near the "tip" of the "trunk". Dr. Sydney van den Bergh only cataloged reflection nebulae near BD stars. The "trunk" is not a reflection nebula.
http://www.tvdavisastropics.com/astroimages-1_00005a.htm
-Tom
Starsearch Observatory
Lat 42N 47' 00" Long 112W 10' 47"
Elev 1752m
Posted 10/04/2010 12:40AM | Edited 10/04/2010 12:41AM #3
That's a glorious shot of the trunk.
Check out the dark "walking baboon" nebula to the upper left of it. It comes complete with front and back legs, long monkey tail, and ears.
I should go after that little cloud with the TEC, looks fun.
Posted 10/04/2010 01:35AM #4
Great stuff Jim!
Cheers,
Tyler
Posted 10/04/2010 11:37AM #5
Very nice looking. (I will also ask about 9 minute subs... ) I hadn't previously noticed you guiding with the C-8, but that makes perfect sense.
Charlie
Darkness - typically 6.5+
Focus - JMI Smart focus
Posted 10/05/2010 04:14AM #6
Thanks for the comments folks.
About the 9 minute subs... Well, maybe this is a bit silly but with my Artemis I could do 4x4 bin test images. With the ST8300 I can only do 3x3 (and actually 9x9 but not 4x4). So I take a 3x3 test shot for 1 minute and say - "well this signal level looks acceptable." Then I figure if I want that level at a 1x1 bin for my image data, I need 9x the exposure time. Hence 9 minutes. Don't laugh.
Jim Thommes
Mak-Newt 152 mm
C8
Megrez II APO
G11/Gemini
ST8300M
Artemis285 Camera
Canon 350D DSLR
