RICHARD COFER
IC 1848
Started by jwillson, 01/22/2009 12:58AM
Posted 01/22/2009 12:58AM Opening Post
Here is my first successful (at least moderately) attempt at merging H-alpha data into an LRGB image--the Soul nebula. Captured in Oakland, CA this past weekend with an FLT-110 apo @ f/6.5 and an SBIG STL-11000 mounted on an Astro-Physics Mach1 GTO. 90 minutes H-alpha (through Astrodon 3nm filter), 30 minutes luminosity, and ten minutes each RG&B. Obviously, I could have used more time in all subexposures, but particularly in the RG&B. Still, I was pleased with the results and particularly pleased that I was able to keep most of the contrast and detail in the H-alpha layer without losing the stars in the luminance layer or creating a salmon colored nebula. Boy, what a difference H-alpha makes on an object like this. Under Oakland's magnitude 3.8 skies I couldn't even detect the nebula in the unprocessed luminance layer--even when stretched. Then add in the H-alpha and suddenly you've got an image!
jwillson's attachment for post 45284
Posted 01/22/2009 03:52AM #1
Posted 01/22/2009 04:38AM #2
Jared,
I think the image came out real nice. Amazing what the H-Alpha can do on an object like this.
I presume since you could not detect a nebula in your luminance that you could also not detect it in your Red exposures? So I am assuming you added some Ha signal to Red?. Seems like you have done a good job preserving star colors.
Jim Thommes
Mak-Newt 152 mm
C8
Megrez II APO
Zenithstar 66 mm APO
G11/Gemini
ST8300M
Artemis285 Camera
Canon 350D DSLR
http://jthommes.com/Astro/
Posted 01/22/2009 05:05AM #3
Great detail !
Regards
LouieĀ  8)
www.atalas.net
Posted 01/22/2009 01:59PM #4
Jared, excellent shot, my friend!
Well done! 8)
Posted 01/22/2009 03:33PM #5
Nice work Jared!
Posted 01/22/2009 04:00PM #6
Nicely done, Jared! Especially under Mag 3.8 skies!
Eric
Posted 01/23/2009 01:05PM #7
Well done!
Good detail and the color looks great for the exposure times!
Jason
