Shane Yarnall
LDN 1622
M33 HaRGB
Started by tvdavis, 09/05/2006 04:20AM
Posted 09/05/2006 04:20AM | Edited 09/08/2006 01:53AM Opening Post
Here's my attempt at adding H-alpha data into my previously imaged M33. The H-a data was 180 minutes unbinned.
It posed some processing challenges; I'm not sure i've got it right yet. The histogram looks balanced however. I'll likely play with it some more.
Comments/criticisms welcome.
Best,
Tom
tvdavis's attachment for post 33279
Starsearch Observatory
Lat 42N 47' 00" Long 112W 10' 47"
Elev 1752m
www.tvdavisastropics.com
Posted 09/05/2006 05:18AM #1
Lots of HII regions Thomas! nice.
Regards
LouieĀ  8)
www.atalas.net
Posted 09/05/2006 05:44AM #2
Hi Tom,
Famtastic shot. Its amazing how many Ha regions it has.
Criticisms? Yes, I'd like to criticize myself for not taking shots as good as yours!!
Greg.
Posted 09/06/2006 03:43AM #3
Tom,
This is a really fine image. It's nice to see these HA regions more clearly like this in these active galaxies.
I've wanted to try it myself sometime. I'm curious at what you did generally to process the datat. My temptation would be to use the HA and straight luminance to construct a luminance channel and then play that against the RGBs on an LRGB process.
I suspect that you may have added the HA data into the red channel as well - a tricky proposition that I see could present some challenges.
Jim Thommes
Mak-Newt 152 mm
C8
Megrez II APO
Zenithstar 66 mm APO
G11/Gemini
ST8300M
Artemis285 Camera
Canon 350D DSLR
http://jthommes.com/Astro/
Posted 09/06/2006 12:57PM #4
Looks great so far Thomas... not sure how much more can be improved... 8)
Posted 09/08/2006 01:52AM | Edited 09/08/2006 01:54AM #5
Here it is again but better color balance. Sorry about the magenta bias before!
http://www.tvdavisastropics.com/astroimages-1_00001f.htm
I broke my scope collimating so I'll be down for a while. You all keep up the great work!
Best,
Tom
Elev 1752m
