Back in November, I had turned my attention to M34. Here is the full size image and exposure / processing details:
http://jthommes.com/Astro/M34.htm
(be sure to click on the image for a full size view)
If you crank up the gamma on your monitor in the full size view, (besides seeing noise and all my data / processing flaws) you can see some small faint galaxies in the 15 - 17 Magnitude range hiding in the noise and jpeg artifacts. There are 2 in the upper right, 3 in the lower right, 2 in the lower center, 6 in the lower left and 1 on the left edge. These were identified from the PGC. Looking at the Digitized Sky Survey, I think there are more.
Megrez II 80 mm APO at f/5.9 (WO FFIII)
Artemis285
G11/Gemini
Guiding - C8 at 1350 mm, DSI Pro, K3CCDTools
An older image from 2004 can be seen here:
http://jthommes.com/MiscAstro/Archives/M34.htm
Artemis285
G11/Gemini
Jim Thommes
Mak-Newt 152 mm
C8
Megrez II APO
Zenithstar 66 mm APO
G11/Gemini
ST8300M
Artemis285 Camera
Canon 350D DSLR
