M57 Ha LRGB
Started by jthommes, 06/17/2008 05:01AM
Posted 06/17/2008 05:01AM Opening Post
I went for a for a deeper look M57 this time. In addition, I took some H-Alpha exposures binned 2x2 for greater signal. I did compress the dynamic range significantly to show the features, so some may find the image a bit unusual. A full size image and exposure / processing details are at:
http://jthommes.com/Astro/RingM57.htm
(be sure to click on the image for a full size view)
C8 at f/7.5
Artemis285 H-Alpha, IR Block, and RGB filters
G11/Gemini
Guiding - Megrez II at 1350 mm FL, DSI Pro, PHD Guiding
An earlier image is here:
http://jthommes.com/MiscAstro/Archives/RingM57.htm
Jim Thommes
Mak-Newt 152 mm
C8
Megrez II APO
Zenithstar 66 mm APO
G11/Gemini
ST8300M
Artemis285 Camera
Canon 350D DSLR
Posted 06/17/2008 06:12AM #1
Wow! I don't think I've seen the outer nebulosity before.
- Jared Willson
Posted 06/17/2008 01:18PM #2
Great stuff Jim, as usual!
Love the nebulosity around The Ring... we don't get to see it often.
Thanks for sharing! 8)
Posted 06/17/2008 01:35PM #3
Looks good Jim,
You picked up the outer ring well,I am guessing binning the Ha made a big improvement here.
Good work as usual!
Jason
Posted 06/17/2008 02:15PM #4
Hello Jim,
Very nice! I need to explore this approach of using 2x2 binning to get fainter components. I'm beginning to see this approach being used on galaxies as well.
Eric
Posted 06/17/2008 03:48PM #5
That's an excellent result, Jim.
It's deftly processed.
Did you also add a small percentage of the Ha into the blue channel?
As a further challenge for this year or some future year, there is an even fainter outer layer:
http://www.stanmooreastro.com/NGC6720.html
but that takes a big chunk of imaging time. It does beg the question: Who knows how long that central star has been puffing out layers? There's a good chance there's an even fainter, older layer out there. It just might require an entire season of imaging to catch it, though.
dan
Posted 06/17/2008 07:11PM #6
Excellent as usual, Jim!
Tom
Starsearch Observatory
Lat 42N 47' 00" Long 112W 10' 47"
Elev 1752m
www.tvdavisastropics.com
Posted 06/17/2008 10:20PM #7
DEEEEEP!! Well done, Jim.
Posted 06/17/2008 11:46PM #8
Nice. I like all the extra plumage and the background galaxy shows up well.
Darkness - typically 6.5+
Focus - JMI Smart focus
Posted 06/17/2008 11:48PM #9
very nice image Jim.
Kevin
