Southern Spiral - NGC 300
Started by jthommes, 12/02/2006 08:14PM
Posted 12/02/2006 08:14PM Opening Post
Here is an image I thought I would share since I know many of my more Northerly friends cannot get this object. Even at 32 degrees north this barely reaches 19 degrees over my horizon. I took most of the data between 15 and 18 degrees, so it was a bit down in the murk. The color was a bit tricky and the luminance was somewhat noisy. The image can be accessed at:
http://jthommes.com/Astro/NGC300.htm
Perhaps Louie or Greg or some of our other Southern Hemisphere colleagues have done this object? I would be interested to see.
Scope was my C8 at f/5.8, Camera was my Artemis285
Jim Thommes
Mak-Newt 152 mm
C8
Megrez II APO
Zenithstar 66 mm APO
G11/Gemini
ST8300M
Artemis285 Camera
Canon 350D DSLR
Posted 12/02/2006 10:55PM #1
Awesome Job Jim ! you pulled out a lot of spiral arm structure out of a tough object with low surface brightness,well done.
Regards
LouieĀ  8)
www.atalas.net
Posted 12/02/2006 11:04PM #2
Beautiful image Jim! I would never even try to shoot so low in the sky, but my skies may be less stable than yours. I am impressed.... again!
Posted 12/03/2006 12:06AM #3
Great work Jim, specially for an object so dim and so low in the Sky... 8)
Posted 12/04/2006 12:52AM #4
Thanks guys for the comments. It is somewhat bold to attempt an object like this so close to the horizon, but the sky stability is usually pretty good due the the Pacific Ocean influence - even 50 miles inland where I was.
Greg - Thanks for the great link on this object - I should have known to check Daniel's site.
Jim Thommes
Mak-Newt 152 mm
C8
Megrez II APO
G11/Gemini
ST8300M
Artemis285 Camera
Canon 350D DSLR
