IR pass filter
Started by vbert, 01/11/2006 11:44PM
Posted 01/11/2006 11:44PM Opening Post
Do any of you have a favorite IR pass filter for imaging the moon? I'm now using a C9.25 so a small bandpass may be an issue with the limited aperature, advice? TIA, Vince
Posted 01/12/2006 02:19AM #1
Personally I like to use a Red filter, like an Astronimik red which is about 650nm. This filter also has IRB built in. You can image this way in B&W with K3 or in colour and extract the red layer. The red filter helps eliminate some of the affects of seeing.
Paul
Paul Maxson
http://www.sunspot51.com
Posted 01/12/2006 06:33AM | Edited 01/12/2006 06:34AM #2
Vincent,
I can highly recommend the Astronomik IR pass filter, opening at 740nm. In a direct comparison with the Baader IR pass it showed a significant advantage.
However to maximise the effect a monochrome camera is needed.
The attached image shows the direct comparison.
Johannes
Johannes Schedler's attachment for post 99848
