After imaging Jupiter in good seeing, I tried for my first RGB Neptune. Finding it with a Toucam took me at least 20min a couple years ago, but with the longer exposures available on the DMK21, it was easy. I set the focuser at f25 off Jupiter, then slewed to the coordinates under low power, recentered, then high power, recentered again, camera in, right on the screen. The Neptune image signal is very weak and it took 100% gain, 150% gamma, and exposures of 1.4 - 2sec to get a histogram close to 50%. Frame rate set to the lowest setting, 3.75. To process the avis, I had to use ninox to pre-sort the frames, then had to hold the gamma in Registax to 1.8 with blurring to enable auto alinging. No cloud details can be seen, but it was fun just to try.
Regards,
Steve
Regards,
Steve
