Comet C/2005 K2 Linear is brightening at a furious rate and is now the brightest comet in the sky! Seiichi Yoshida
http://www.aerith.net/comet/weekly/current.html
has it at the top of his list of bright comets at magnitude 8.5 .
I have a recent modem-friendly movie and supporting information on it at
http://home.att.net/~dpersyk/new.htm
Be forewarned! K2 is a very fast-moving comet. It is racing along at 7.8 arc seconds per minute relative to the fixed star fields in Ursa Major. It is imperative that you use fresh ephemeredes to locate it. I’d suggest
http://www.cfa.harvard.edu/cfa/ps/Ephemerides/Comets/2005K2_1.html
but even then you only have it located to within a day. You will note that its coordinates are changing considerably from one day to the next.
I use my planetarium programs (SkyMapPro and Guide 8) with fresh ephemeredes to help me locate the comet.
At magnitude 8.5 it should be an easy target for most scopes, but you may have to hunt around for it a bit if you do not have exact coordinates. This comet is quite unusual and may not last much longer, so I urge you to grab it while you can.
Clear skies,
Igloo Observatory Home Page http://dpersyk.home.att.net
Hampshire, IL
New Images http://home.att.net/~dpersyk/new.htm
Clear skies,
Hampshire, IL
