Tricolor imaging with an 8'' scope
Started by rjl, 03/06/2008 02:05AM
Posted 03/06/2008 02:05AM Opening Post
Dear All
I have been using a Phillips Toucam 840k to image the moon and planets for a year now and would like to improve my imaging system by moving to a monochrome firewire camera. Is it practical to use filters with a camera like this with a relatively "small" telescope with an 8 inch mirror? I notice that most of the tricolor images come from guys with larger scopes
Thanks for your help
Richard.
Posted 03/06/2008 09:29AM #1
Richard, I moved to monochrome camera + filters on a 10" scope, and saw immediate improvements over the ToUcam images I'd been taking. I don't know about an 8" scope, but I'd suggest that any scope would show improvements with mono+filters as compared to colour on that same scope.
regards, Anthony
http://www.acquerra.com.au/astro
Posted 03/06/2008 11:17AM #2
Richard, Ed Roach has been producing stunning images with his 8" scope for awhile. Check out his web site, http://www.edwardroach.com/ He combines Toucam color + DMK Lum which is another way to go.
Regards,
Steve
Posted 03/06/2008 02:03PM #3
Richard,
When my Mewlon250 was getting maintenance I did LRGB imaging with my TOA-130 (5.1") scope of Mars. I didn't find it to be a problem. Check out my webpage for some of my images if you want.
Paul Maxson
Paul Maxson
http://www.sunspot51.com
Posted 03/06/2008 03:11PM #4
Hello Richard,
I believe that using the toucam for the RGB portion will be more than enough to obtain great LRGB images. The RGB portion is not of great importance: it is the luminance that gives you detail. Most of the people that do LRGB blur the RGB portion in order to reduce the noise contributions that usually derives from the color channels.
Ciao Richard
Luca
www.amun-ra.org
Solar Imaging Website
Posted 03/07/2008 01:17AM #5
Dear All
Thank you for the valuable advice. I have ordered the camera and will try the tip of using the Toucam for the RGB initially. I am very much a novice in this area but hope to put up some images shortly. Certainly the work on your web sites is very inspiring.
