Here is an old favorite for this time of year - Horsehead and Flame. It is also first light on a WO Zenithstar 66 APO that I recently picked up. I also used the WO FFIII (works well for both the WO 80 mm and WO 66). Between the two I can range from 555 mm FL to 280 mm FL. This image was at the 280 mm FL - remember, I have a small CCD.
I used an H-Alpha filter on some 10 minute exposures. There was some star trailing - which I processed out - but the nebula softness was not correctable. I think the single foot mountinmg on the Zenithstar causes some flexure; guiding was fine. I'm going to get rings for it - I think it will help.
Anyway, the image as well as exposure and processing details are here:
http://www.jthommes.com/Astro/Horsehead-Flame.htm
Zenithstar 66 mm APO at f/4.3
Artemis285 IR/UV Block, H-Alpha, RGB
G11/Gemini
Guiding - C8 at 1350 mm FL, DSI Pro, PHD Guiding
An older image made in 2005 is here:
http://www.jthommes.com/MiscAstro/Archives/Horsehead-Flame.htm
G11/Gemini
Jim Thommes
Mak-Newt 152 mm
C8
Megrez II APO
G11/Gemini
ST8300M
Artemis285 Camera
Canon 350D DSLR
http://jthommes.com/Astro/
